2000, 2500, 4x4, 5spd, stock truck, 314,200 miles. Made a short mileage run to the trash station earlier today and had this happen. Started truck to warm up a bit before leaving. Drove 5-6 miles to trash station. Weighed in, and then parked truck and shut it off as the line was long ahead of me. Parked on an approximate 30 degree incline (front end higher) for maybe 5 minutes . Restarted to move in line, and immediately the truck begins to idle rough, like i have experienced in the past with ff changes. Got it up on the level, and even slightly nose down, still idling rough. Back in, shut it off. Unloaded. Got back in hoping it would start, and it did, ran like normal. No problems with power on the way home.
This is the first time that I can think of that the truck was parked on an incline as mentioned above. Everywhere I park is either level or slight nose down.
Details: full tank of fuel with 60 miles on it filled up last week). Reputable fuel supplier. (Don't fill up when they are unloading). Fuel filter was changed last fall, due again at next oil change, next month. No fuel pressure gauge ( I know...I know). Lift pump around 2 years old, hummed its usual 15 - 20 seconds at first startup (didn't pay attention to subsequent starts). Temperature around 30 degrees. No fuel is showing up on the ground.
Your thoughts? Thank you.
