steved said:But air can still compress a lot, unlike a fluid.
steved
cojhl2 said:Very true,, but where is the pressure gonna come from to compress it. If you are filled to the top, where is the added head??
No matter how you work this issue,, if the tank is full to the top and the fuel expands it will run out the top. .
I think the short answer is thermal expansion adds the head, the relief valve inside the fuel cap allows some extra head to build and compress the air before fuel comes out.cojhl2 said:Very true,, but where is the pressure gonna come from to compress it. If you are filled to the top, where is the added head??
Nate said:I'm sure what you mean about that 3/4" piece of tubing. . can you explain a bit more?
Thanks!
Nate said:I wonder if that would work?
