Fuel Filler Hose
Would clamps prevent leaks by themselves?
  • Don't need to use a sealant.
    Votes: 3 42.9%
  • Use wide hose clamps only.
    Votes: 4 57.1%
  • Total voters
    7
What is your read end?
Had to remove my stock fuel hose from the tank to the filler neck the other day. While examining the inside of the hose I noticed the factory applied some sort of cememt (black in color) to both ends and secured each end with a hose clamp.
My question is: Do I need to apply another coating of sealant to the hose ends to prevent the possibility of leaking? If so, what type of cement/sealant? NAPA guy doesn't sell anything that stands up to gas/diesel applications.
Any and all ideas welcomed. Thanks!
Dave:confused:
I wouldn't use sealant on the fuel filler hose. Radiater hoses hold much more pressure with no sealent on them.
If you do decide to use anything make sure you can get it off later in case you have to pull the hose again.
I agree there is really no need for a sealent on the fill hose. There is little to no pressure that a hose clamp cant withstand
Back On W/O Sealant
Thanks guys! I put the hose back on dry yesterday and filled the tank. Saw no visable signs of leaking while slowly filling and thus far no leaks from standing overnight with the filler neck full as well.
Guess the factory applied some sort of lubricant for . easy insertion. :D
