fuel filter...and extra fuel
Horton Fan Clutch
posting pictures
. . changing my oil last night and and also the fuel filter. Got to thinking about the spare fuel filter behind the seat that most of us carry.
In the case of emergency use, what will you guys do? Slap it on and bleed a filter's worth of air manually or do you carry just a little extra fuel somewhere to prime the filter? Or?
me... I have always dreaded manually bleeding the lines...
gary
'92 W250 LE 4x4, NV4500 5spd, Borgeson steering shaft, PrimeLoc
Bleeding is no big deal on mine. The bleeder screw just above the filter allows us to manually pump with the lift pump and have it primed in about 30 Seconds. No problem really. Better than handling a wet filter and trying the thread it on.
Maybe I missed the point #ad
Jeh
Jason Hoffman
Lil' Mack - 89 D250LE 5 Spd 3. 54 Reg Cab. K&N,"tweaked pump", BD Injectors, Banks Pyro/Boost, 3. 5" Exst tail section straight. E&M Custom seats. Bosch H4, PIAA 80W/80W HdLites. 100W Drv,55W Fogs. 237,500 miles (380,000 Kms) 7850 Hrs.
Cummins Power Booster member.
The Original Turbo Diesel
Lil' Mack Pics
I do about the same as Lil Dog except for how I fill the filter. What I've been doing is to screw on the water sensor and then screw on the filter but leave it loose. Use the lever to fill the filter and then screw it on down and hook up the sensor. Works good for me with no problems. Don't need to worry about keeping fuel fresh in a can that way.
Stan
93 2WD extended cab, Banks Power Pack, K&N Air Filter, PW Injectors,Auto w/4. 10 rear with limited slip, US Gear Exhaust Brake, 31/2" Exhaust, 5K air bags, Boost/Pyro/Tach Gauges, Green/Silver, new 40-20-40 bucket seats, 149K
