fuel filter change 2005 powerstroke
Old Ford diesel...new ulsd
I6 versus V8
Sorry to bring this up on the TDR, but my friend want's me to change the fuel filters on his ford and I need to know step by step the proper way? Will they start right up after change or do you have to crank the starter some? It look's pretty strait forward but would just like some information first hand. Thank's and happy new year Don
theres 2 filters. one is in the HFCM on the inside of the frame right under the drivers seat. there is a drain plug (hex) in it to drain the fuel out before you attempt to loosen the cap and take a diesel bath. once that is drained, loosen black cap with I believe a 36mm socket and swap out filter and washers. second one is on the top of the motor next to the oil filter housing (smaller of the 2) thats pretty self explainatory. loosen cap, change filters and washers, reinstall. as for prime, turn key to run position and listen for the pump to run, cycle key 3 or 4 times until you notice a change in pitch of the pump then the air is bled from the system. truck should fire, may have some white smoke for a little while.
Good luck, Jim
