Just a heads up to the guys that have not read my sermon on fuel filter changes. THEY ARE NOT SET BY TIME OR MILEAGE.
Today was the third time I went out and checked my fuel pressure, pre and post filter with a temporary gauge I use, and found a drastic change in pressures from the last check. Normally I check it every 2500-3500 miles. Prefilter was 12PSI at idle just like it was 3000 miles ago, but post filter was down from 10 to ZERO. Anything above an idle was pulling a vacuum!! The filter had a little over 20K miles on it, but only 3000 miles ago was only showing 2PSI of restriction, meaning that it had CLOGGED in 3K miles. This is the third time I have seen the filter clog in a short period.
Get a temporary gauge at least and USE IT, check pre and post filter pressures every couple thousand miles. The good filters you don't throw in the garbage because it "was time" to change them will pay for a pressure gauge in no time at all. The best way would be to have pre and post gauges mounted and monitored all the time, and even that setup could be payed for by not throwing out good filters in less than 100K miles. I have gone a little over 30K miles on ONE filter, and as little as 4500 miles. Without a gauge I would not have known either way. Changing them for any other reason but restriction is a guess and lots of times is a waste.
