Had a FASS HPFP 95 fuel pump installed a while back, instead of the $600 intank fuel pump replacement recommended by Dodge for my 04 with the non-op fuel filter mounted pump.
Just changed my stock fuel filter for the first time since HPFP install, but now I have a loud pump (fast buzzing) noise in firewall area of dash where fuel filter mounts on opposite side. It cycles on for 10 sec and off for 5 sec, if engine is running, or ignition key is just on.
I think I have air in the fuel filter or (?). Engine starts and runs nicely, but new noise needs to go.
UPDATE 11:24AM - Just traced noise to the vacuum(?) pump mounted under the passenger side hood mount. There is a skinny black plastic tube going across the firewall and by the area of the fuel filter on its way to the driver side battery area. Did I break something connected to this vacuum line causing ti to leak down?
Any and all advice and experiences welcome.
Thanx,
Joe
Thanx,
Joe
