Today was the 3rd time I've change my fuel filter & this time was the easiest of all... . On the 99's you have to drop the bottom off the canister. This time instead of cycling the lift pump umpteen times to refill the canister & filter, I pulled a plug I have from the post filter gage test port & that allowed my to fill the canister (a little bit of a mess, I'm working on that) & with bumping the key once & cycling the LP I was able to fill the filter canister, re-plug my test port & the truck fired up immediately. Awesome compared to the cycling of the lift pump 7-10 times. I thought someone might find this info useful because re-priming the filter is the only part of changing the fuel filter I dred...
Clay
Clay
