Fuel Filter Change Warning
D
2015 Ram Builder now avaiable online
Truck rear differential is too hot to touch.
Just changed the two filters yesterday on the 2014 with 7500 miles and 18% left on the evic reading. Thought I would do this since I am also changing the oil due to the 6-month requirement. I drained the rear filter and then disconnected the wire on the bottom of the filter. Used a large crescent type wrench to unscrew the device on the bottom of the filter and was surprised how much more diesel fuel spilled out. Then used a large channel lock wrench to unscrew the filter and got drenched in fuel. The filter holds more fuel than you expect and fortunately I was wearing my reader glasses or I would have had fuel in my eyes.
So if you have not done this before, beware and be prepared with drain pans and rags. BTW, I put a hose on the drain connection and a lot of the fuel went down that hose but additional fuel leaked around the threads of the drain and I was not prepared for that. The truck sat for two days before this procedure so it was not due to having recently pressurized the system. The front filter was like our previous trucks except the new filter came out in two parts. The instructions with the Mopar filter are to drain all the fuel out of the filter and then check for debris. The interior of the filter housing is black and the location makes it almost impossible to see into the bottom of the housing. And yes, the cap was installed by the gorilla. Left some blood having to get down on the filter with a socket/ratchet to break it loose and then I was able to use the long extension with a swivel as previously recommended. Very tight fit getting the new filter in place but doable.
Now, onto the oil filter. Sheeeesh!!!!Lord have mercy they have made this difficult for us. I have pity and a new respect for those who service these trucks for a living.
One can never "over maintain" a truck, but I believe you'd been OK waiting closer to the 15k mark in regards to the fuel filters. If memory serves me right, there's maybe only a 1 year or 15k requirement on the fuel filter replacement.
In any event....the next time you change the frame mounted filter, try this....disconnect the WIF wiring from the frame rail, then connect your vinyl tubing / hose to the fitting. Open the drain valve and allow to drain into a pan or a jug. Loosen the frame mounted separator and unscrew about two to three turns to break the seal. Move up to the underhood filter and start draining it. Allow a little time, then go back to the frame mounted filter. It should be 95% drained in short order if you indeed did break the seal.
I *think* there's a check valve in base of the frame mounted filter head. Since you removed the WIF sensor first, then unscrewed the separator, that's the reason you were drenched in good ol' aromatic #2 diesel. :-laf Don't remove the WIF sensor until the separator is removed from the truck.
Hope this helps!!!
https://www.turbodieselregister.com/threads/248375-Fuel-filter-change?p=2398701#post2398701
https://www.turbodieselregister.com...tomy-of-a-MOPAR-Fuel-Separator-p-n-68197867AA
Yes it does and I had already made up my mind to one again purchase the old style filter removing tool that clamps on. Forgot that part of the instruction link you sent. As for stretching the milage, I had heard/read that the vehicle will go into a limp mode when it reaches 5%. The fuel I am purchasing may be contaminated and I am going to try another vendor for the next 7500 miles and see if that increases my mileage. At 18% now and falling rapidly, I was afraid that I would get caught out on the road. It went from 25% to 18% in the last 800 miles.
On the Cummins forum, there was a thread about a TSB fuel filter reflash, #18-018-13. It was said that some trucks have a flash that the EVIC is on a 7500 mile schedule, this flash is supposed to put it to a 15,000 mile schedule.
Sam
Your truck WILL NOT go into a limp mode at 5% filter life. I just ran mine down to 2% (9524 miles and 591 gallons of fuel). What was strange.........was the filter life was down to 1% when i decided to change filters. The percentage jumped to 91% WTHOUT me resetting it........so I changed the filters and then reset the percentage back to 100%.
I still can't get an answer from my dealer as to how this thing judges filter life. Algorithm or pressure differential? Ram4sam, if your TSB is correct, that would indicate an algorithm.
i'm no expert here.........:eek: just spitballin'.....I would bet it is just an algorithm, just like the oil life. If it was a pressure sensor, where would you put it.....between the tank and the rear frame filter, between the rear filter and the one under the hood, or between there and the injection pump?? I'm getting dizzy..... To anyone with an Edge CTS......is there a fuel pressure reading available on it????
Sam
Well, I will push it further next time knowing it won't strand me somewhere in east Egypt. Or Detroit. My front filter had more contamination than I expected after seeing the link above with pictures. Not a lot lot but but more like my 2004 truck. The double filter there really would not let any of that through so it seems to be a good design. I just need to rearrange a clamp or whatever it was to cut down on the blood loss getting to it. The warranty has expired on my skin and joints and my arms look like I have been crawling through bramble bushes. Sure appreciate the feedback on this issue. With the cost of these filters I need to get the most miles I can out of them.
