Hello fellow TDR Members. I need to change my fuel filters and was wondering what the difficulty level is. I hear there may be more than 1 Filter. Looking for vids or instructions and feed back on the PITA factor.![]()
Not worth the gamble. Stick with Mopar, Fleetguard, or Racor.Anyone use the aftermarket filters??? There like 1/2 the price as the Mopar?
Throw’em on there and you can be the test dummy.Anyone use the aftermarket filters??? There like 1/2 the price as the Mopar?
If you "like" it, you can then later unlike it.Sometimes I wish there was a dislike button....
I changed mine this afternoon. Bought the package filters from Gino's. The only problem was the rear filter didn't drain completely so when I spun it off it still leaks fuel. The rear filter was on there pretty good and I had to improvise a little bit to get it off.
Add a 1/4" hose to the drain port and then open the valve. Then loosen the filter and the rest will drain out. Close the drain and then spin off filter. I also loosen the drain before loosening the filter and snug it back up to make it easier to spin off with the filter removed.
