Details here: TDR Privileges
Hello, I'm a new TDR member and have a 02' 2500 4x4. Can anyone give advice proper procedure to change the fuel filter and avoid any problems like allowing air to enter the system, etc. Thanks, Tony
I drain about a pint of fuel before removing the filter cap and clean inside the canister with a lint free cloth. I then fill the canister about 2/3 full with clean diesel fuel and slide the new filter in nice and easy (Don't forget to replace that o-ring). Torque to the proper spec, bump the starter once and you should be good-to-go
