I just discovered that Dodge installed a fuel filter last week that screws into the base of my stock fuel filter housing, and requires that you pry the cover off of a disc on the top of the filter before you can remove the cover and set it aside. Now, instead of simply lifting the filter element out of the canister, it has to be unscrewed as it has a 1/2" (?) plastic pipe thread nipple on the bottom of the filter and it screwed into the base of the filter housing.
I've never seen a filter like this designated for my Dodge, and the fact that there are threads that can possibly come away from this fitting and make it to my pump are bugging me. The only filter I've ever seen, including the new Baldwin I just received, simply clamps into the lid and is held by pressure against the outlet of the filter housing and the rubber gasket on the bottom of the filter.
Does anybody know if this is the new standard for fuel filters for the 2003 Dodge Cummins, or, did they manage to get the wrong part installed?
