I helped a friend this morning by installing a Vulcan kit (believe it or not, he's seeing 19psi at idle from a stock pump now ... lucky bugger!). Once everything was tightened up and the engine running, we found a leak at the WIF drain valve. He has never opened it before today and now it's leaking from the top, where the lever enters the plastic housing. Is this rebuildable or does he need to purchase a new drain valve? If rebuildable; are the seals something that's available from Home Depot/local hardware store?
Any help would be greatly appreciated!
