Archived fuel filter housing needed ASAP
Archived HELP! No shifting on 2006 48re
Archived Need Answer ASAP
Does anyone have a fuel filter housing to fit a 99 24 valve that they want to sell? Mine cracked at the test port fitting and is spraying fuel. -- email address removed --
My 98. 5 FF housing did the same thing on the test port fitting. I flushed the stock raised fitting down with a die grinder and re-tapped in the top part of the housing; clean good under the fuel heater and your done. Has lasted for 65K with the plug removed several times.
Could work if the entire top is not cracked.
Ditto
Dan
