Engine/Transmission (1994 - 1998) fuel filter housing
Engine/Transmission (1994 - 1998) oil spitting out of the dipstick
2nd Gen Non-Engine/Transmission Oil sample is in.......
I was looking at get a fuel filter relocation kit from Geno's for my 12 valve. Then this came to mind I have the old filter housing off my 2002 when I put the FASS pump on. I'am thinking of putting that filter housing on the fire wall and plumb it in. My question is do I plumb it in between the transfer pump and 12 valve housing or between the p-7100 and filter housing? Will I be able to use fuel line hose I don't know what kind of pressure is in that line.
Are you saying that you want to run two filters? If you are trying to avoid changing the stock filter, then you should run it in between the lift pump and the stock filter. This way, it should pick up most of the junk meaning that your stock filter will last a lot longer. It would be interesting to see how much a second filter of the same micron rating would pick up(in other words, how much the first one missed).
