The filter retention in the cap is fairly obvious when you look at it. There's a series of small plastic retaining clips with barbs on them that retain the filter. Just push the filter into the cap fully until it snaps into place.
As always, only ONE o-ring is required. If you try to use both, it will leak.
The owners manual should have easy-to-follow filter changing instructions.
1. Open the drain valve until no more fuel comes out.
2.
Close the drain valve.
3. Using a 1-1/8" socket, unscrew the filter head.
4. Pull up on the head to remove it. The filter has to slide off the center post inside the canister, so pull hard.
5. Pull the old filter off the underside of the cap. The easiest way to do this is to pull with a slight twisting motion, like how you remove the cap from a can of spray paint.
6. Remove the o-ring.
7. Resist the urge to try to clean out the inside of the canister. If you can't resist, then at least use
lint free cloths!
8. Install the new o-ring to the cap.
9. Apply some
clean engine oil to the new o-ring.
10. Press the new filter into the cap. Do this similar to the way you'd put the cap back on a can of spray paint.
The open side of the filter must be pointing away from the cap. It will
snap into place.
11. I like to put a little engine oil or fuel around the lip at the bottom of the filter to help it slide along the center post. This isn't strictly necessary.
12. Screw the cap on
by hand (to ensure you're not cross threading it).
13. Torque specification is 25 ft*lb, but I normally just snug it up.
To prime the system on pre in-tank lift pump trucks, bump the starter but don't start the engine. This causes the lift pump to operate for 25 seconds. I'd do this 2 or 3 times before starting it.
To prime the system on post in-tank lift pump trucks, just turn the key to run for 25 seconds or so. From what I've read, the in-tank pumps will run for 25 seconds when the key is turned to run without the need to bump the starter. Do this 2 or 3 times.
Start the engine, check for leaks. Piece of cake.
Ryan
