this was the third time I have changed my fuel filter in 2 years! the first year I did not change it. this last time was 2 oi9l changes (about 8k miles since the last change.
when I change it this time, I found a greassy substance on the bottom of the fuel canister, almost like vasoline. it apparently was corrosive since the canister was discolored and pitted where it came in contact with the substance. I cleaned the canistor and sanded the pitted areas, cleaned again and rinsed with diesel before proceding with filter replacement. ??? what was this stuff, it can't be good for the injector pump or injectors! what can I do to avoid this in the future? anyone have any ideas???
Second, this as I said was the third time I change the filter with the same results! I try and follow the recomended procedure,( remove canister and clean, new O rings, soaked in diesel, fill canister with clean diesel, replace and retighten canistor, purge air by loosening outlet side plug bumping ignition, while lift pump is running tighten plug after diesel flows. problem can't start, crank crank, crank, no go! the only way I can get her started is by loosening a couple of injector tubes at the injectors, crank crank and crank until diesel starts flowing at loosened tube, retighten and crank some more, it then starts. I am afraid I am ruining the started, and/or the battery. try not to crank more than 30 sec at a time and then wait a min or 2. whole procedure takes 20 min or longer after replacing filter canistor. what am I missing???
1999 3500 quad cab, auto aero fendor trim and running boards,
bugflector II, K&N filter, Geno's monster tip
