I have a question for the experts. It appears that we all would benefit from a 2 micron fuel filter. However, the stock lift pump is not strong enough (hence the new 7 micron wonder filter -- cheaply made I might add -- I was shocked that Fleetguard would make such a cheap looking filter). It is my understanding that the CP-3 has an internal low pressure gear pump. Would it be possible to split the line between this low pressure pump (80 psi as I understand it) and the main high pressure pump and plumb in a high quality 2 micron filter there. This would avoid the current lift pump issues. It is my impression that the Dmax uses something like this for its fuel filter (I know that they do not use a lift pump). Thus on our Dodges the lift pump would push fuel through the stock filter into the CP-3 low pressure gear pump which would raise the pressure and pump the fuel through a good 2 micron filter which would then feed the high pressure section of the CP-3, rail, and injectors.
