Engine/Transmission (1994 - 1998) Fuel filter relocator
2nd Gen Non-Engine/Transmission Squealling from the rear axle
2nd Gen Non-Engine/Transmission Would you do it....
It's nice now that it's in but man what a PITA to install. It was like changing the fuel filter 3 times in a row. But now it will be a breeze to change the fuel filter,and drain the water. And it looks nice too.
I put in the Ashland primeloc filter relocator. Ashland doesn't make anymore but I found a guy on here whose wouldn't fit because of his Banks kit. So he sold it to me. Ashland has the number to all there former dealers,you can call each dealer til you find one that still has it in stock or call Ashland and request one, they told me if they get enough requests they might make another batch of them. There is a link for them under the site features.
I just slightly relocated the fat wiring harness that goes across the back side of the intake cover plate and I can get to mine fairly easily now. I also moved the two relays that hang down by the brake booster and got them out of the way, that helped too.
Vaughn
Do what Vaughn says, then if you have a vacuum booster ('94, '95, '96) you can remove the two nuts that hold the master cylinder to the booter. Then lean it toward the fender. Plenty of room. I don't know it this will work on a '97 or '98.
