tmarti,
Did you get your P-Loc from Geno's? If you did you might have noticed the indicator they offer that installs on the forward edge of the remote filter head. It is sliding type tube gauge that shows green while the filter is in the 5psi range of restriction. It easily screws on with a series of restrictor plates, seals, and allen type screws over the two 1/8 ports in the front edge. The downside is it doesn't actually give a reading in PSI before or after the filter. It is only an indicator warning when the differential between pre and post filter pressures is more than 5psi.
In essence it serves a similar purpose as the Filter Minder on the airbox.
As for an analog pressure gauge, I was told the same two ports that the above gauge uses can also be used to plumb in a regular PSI gauge, but for whatever reason electric gauges (specifically the sending units) don't last very long on the 12V's.
