fuel filter / water separator
Strange feeling in the steering wheel ?
Auto Transmission Failure
I need some info. Service manual Says" Hold drain valve open untill all water and contaminants have been removed and clean fuel exits drain hose. " When I open drain I get about 2 drops, then nothing. not even clean fuel? Before I start tearing it apart thought I'd ask the knowledge base. Thanks in advance.
Love that turbo diesel! :D only my 2 post.
Try leaving the valve open a little longer. You could open the valve and hit your key to turn the pump on for a second although that might make quite a mess of fuel. I just changed my fuel filter for the first time. Instead of filling the housing the hard way I left one of the pressure test port plugs a bit loose and turned on the key. It filled up the cannister but also made quite a mess before I could get the plug tight. By the way I've never got anything but clean fuel out of mine, hardly ever drain it. :)
ditto on the above, just keep opening an closing it, then leave it open and watch, you will see the fuel and water (if any) come out.
