Originally posted by Joe G. :
What year? It makes a difference since the power brake system changed.
hv2hunt
Member
posted 03-26-2001 10:26 PM
it's a 98
OK--I bet,then, that your brakes have 3 steel hardlines coming from the master cylinder, and a veritable birdcage as it all goes in and out of some horrendous little valve assembly.
I also suspect that you have the canister type of filter, way towards the back of the block, near the firewall.
There's a big central nut on top of the filter header. it doesn't come off, but it does hold the canister on. (the can is made with a boltstud that rises from the bottom of the can)
Find the yellow valve lever. At the lower end of its shaft is the actual valve and the little hose that is for drainage of the canister. Get an old soda bottle or a jar to catch the contents, and turn the drainvalve open. Once it's empty, close it again. Then, loosen that big nut we talked about, and also, rotate the canister off its locks (kind of like a push&turn medicine vial)
once unlocked, and de-nutted, it will come off in your hand. You can then snake it out by bringing it forward towards the battery until you find a clear tunnel.
YOur new filter will have 3 O-rings, one about 3/4", one the same diameter as the cannister and the other about 3/8" (this may be a lie, due to time. . I've had a Primeloc for about 1-1/2 years now). Find their corresponding old ones on the old assembly and replace them all,being careful not to nick any of them, as they are the only separation between clean and dirty fuel. Oil them slightly with Diesel, so that they will seat properly. Emplace the new filter element into the can. Once that's all assembled, if you can snake it back into position upright without spilling your pre-prime fuel, then do so, and replace it onto the filterheader. I was unable, so I rested it on the framerail, filled it with clean fuel,and replaced it on the header. Tighten everything up the way you found it. Voila! You're not done, but you are close
Near that big header nut, there's a little valve-screw. loosen it. under-neath the filter, on the side of the block, locate the manual liftpump. It's a plunger covered by a rubber boot. It'll be easier to find by touch than by sight. Just have your watch, rings, etc off while you feel around in there, in case you discover electricity!
Pump the plunger a few times until the airbubbles are cleared from that little valve. (alternately, you might also have success by turning ign key to "on" position and letting the electric pump do the work)---Close the valve.
Crank the truck. It should fire, may sputter and cough a bit, and then run smooth as the last bubbles travel thru the injection system.
I did it twice,and decided to give myself a Primelock for my 35th b'day. best $185 i've spent!
mildly BOMBed 98. 4 1B7KF23D4WJxxxxxx-- BD's #5 plate and 210HP injectors--BD Brake and the associated transmission bomb goodies (except for TC,currently), 4" open exhaust (short),Psychotty, camper shell, Warn front receiver, G159Unisteels on Rickson 19. 5's. . CD player is bone stock, so are the seats. PrimeLoc, also remote spin-on filter for the auto trans... Pyro,Boost and Trans temp from Isspro,
Westin nerf rails(black),
bent welding rod to hang celphone on dashboard...
240HP on Dynojet from 75-105mph drumspeed.
