where do you get good fuel filters for the 07 dodge ram 3500 trucks with the 6. 7 liter diesel engine? please provide names and phone numbers. thanks big white
it will not jepardize the warranty. things like K&N air filters that can dust a engine in short order justifiably voids a warranty for a dusted engine. your truck needs the better filtration and it also needs a oil bypass filter. you need to delete as fast as you can to get max life out of your 6. 7.
thanks for the pics. by the way do you have any instructions on how to install more fuel filters for the 3500 trucks. i need all the help i can get. thanks
How many miles on the truck with the pictures above? If that was the 67,500 cleaning, then I'm doing it at 30,000 miles intervals for the EGR/EGR Cooler/CCV Filter/Grid Heater cleaning(s).
I wonder if yours will be better or worse with the EFI Live?
Pull it let's see
I don't have a lot of miles on EFI. So most of any would be from factory stock. I know from beta testing with the EFI, the factory stock leaves a lot on the table. Including cleaner tune from EFI adding hp.
Thanks Bob! Let me see if anyone is going down your way from up here soon.
Sounds like alot of fabbing and drilling when u can buy a xx-fuel filter system and install it in an hour or less... . not a bad price and works nice with the WIF light... .
