SSolderitch
truck has a fass 95 lp. Gauge fuel line is on the vp44 bolt.
gauge niormaly shows 17 psi - 15 running & 12-13 wot
over the past year droped 2 psi so I see 15 idle & 13 running.
changed vp44 - gauge worked the same as before the change.
Then I did a filter change & pre screen filter change - lost 1 psi at gauge?
I would see the gauge bounce with the 1 second lp pre-start
I topped off antifreeze to gauge line - gauge would sit at zero for 15 seconds then move slowly to 15 psi - takes another min.
I thought a pinched tube so I releaved the A-pilar behind the gauge and refiled the tube leaving no air. No bends or pinch points.
broke loose the fuel line and the big screw on the isolator to vent any traped air on the fuel side.
still no pre-bounce & 15 sec at zero & a slow min to get to 15 psi.
Trucks runs great but I don't like the motor started and the gauge sitting at zero..... Do I have a gauge, filter or lift pump problem?????????????
never had this before, What am I missing?
