Fuel Gauge in cab--Isolator necessary?
k+n FILTERS how good are they?
Tailgate Lights
I am doing gauges soon, and considering a 3-gauge setup (with Autometer's new on-dash pod, pn 15002) with fuel pressure as the 3rd gauge. I plan to read the pressure between the filter and VP44. In the Autometer catalog, it lists a direct-reading gauge (pn 3311), and then one with an isolator (pn 3313). Since diesel doesn't go "KaBOOM!!!" like gas, I think I'd be OK running the direct gauge setup in the cab. The main risk is a fuel leak in the line, which would mean doing a good job on the teflon tape application #ad
. What do you think? Should I spend extra for the isolator setup?
Vaughn
2001 ETH/DEE QC shorty 2wd
Vaughn,
It boils down to what you feel comfortable with, but I would seriously consider keeping fuel out of the cab. Even though the Auto Meter isolator set-up is quite pricey, it's a trick set-up.
'99 3500 QC 4x2, AT, 4. 10 LSD, camping/towing pkg. , Mag-Hytec rear cover & trans. pan, Auto Meter gages, K&N air filter, Mopar bed liner & mud flaps, Prime-Loc fuel filter relocation kit, Tekonsha Sentinel brake controller, Rancho step rails; Air Lift SD air springs
