Hi, i bought my first 24 valve cummins today- mainly for the driveline (parts truck). The guy said the engine ran great, but after they changed the drivers side front fender there was only fuel on 3 cylinders. I ruled out any air leaks by hooking new rubber lines right onto the supply and return and into a container with diesel under the hood. Electric lift pump cycles good and lots of supply pressure. Problem is that the fuel seems to be flowing straight through the injection pump without any cranking. If the lift pump is on, fuel goes right through the injection pump. Is this pump broken inside? or can this be caused by an electrical problem. It seems to be only leaking through some of the outputs on the IP. Nor familiar with these pumps, but seems like the IP must be toast. Thanks for any help.
