Joe G. said:
Fuel heater/pre filter assembly part numbers
Fuel supply line fitting grommet (Cummins) 3923194
Fuel Strainer (Mopar) 04762962 (Cummins) 3847102
screen kit (FleetGuard) 3845400-S
pre-filter O-ring (FleetGuard) 3834185-S
heater element (includes 3834185-S) (FleetGuard) 3907766-S
cable harness (FleetGuard) 3843722-S
These part numbers may be out of date, but if they are Cummins will be able to find current numbers. There may be a couple of variations of this thing so have the CPL and serial number of your engine when you go to Cummins. The gasket (o-ring) above the fuel heater is the same as the one below it on mine. The screen kit contains a O-ring. Just for information you might want to drill out the three rivets that hold the heater together and post some pictures of what it looks like inside.
