Fuel heater wiring
New Power Mod Install/ Help!
what good is the intercooler??
When I was under my hood last replacing that B. S. throttle cable AND throttle linkage rod(because one end was bad, can't be bought separately) I saw the fuel heater connector smoking and burning up from arcing. It's now spliced in, but does Dodge make a pigtail of any kind? I'm getting really tired of these problems. My fuel guage is broken too.
Nick-95 2500 CC 4x4 5 sp 4. 10 Skyjack 2 1/2" Lift BFG 315 75/16, Bedliner
You're probably better off just using solderless connectors like the rest of us have. Why replace factory crap with more of it?My 94 did the same thing as others have had this problem also.
94 4x4 SLT Geno's guages,TST 230/605,straight pipe from turbo,115,000 miles, horton fan clutch,RS9000 shocks, BD torque converter,valve body and pressure lock,Scotty air
Niki,
Fuel gauge is reoccuring problem with most trucks.
Try junk yard get one off of newer model if same type who knows they mite have come up with better one.
Bill Thomas
Missouri Mule - 96 Wht 4X4 ST CC,5 spd, 3. 54, 8 ft bed, 1 ft high cheater boards.
99 Freightliner bl/wht FL60 ISB-5. 9 24v,215 hp,520 tq,6 spd, 3. 59 nsr,16 ft box, 19. 5 tires,Wt/gvw 11,000/23000
I keep reading about this fuel heater. I have a 1996 model and I am wondering where this fuel heater is located. Could some one give me some directions in locating this heater.
If you know where your lift pump is, it's right next to it.
It's in the screen strainer.
98 Quad cab 4X4 2500 12 valve,5 speed,3. 54 rears, 8' bed. Michelin 275 75 16 lr-E. Boost and egt gauges but basicly stock except for a "properly adjusted" AFC. Cat in the garage. Uniden HR 2510, Texas Star 1200 amp. 63,000 Mi as of 1/27/01.
NRA life member. High power/IDPA.
HEMI®Dart,
You must be a contortionist to get a good almost level photo like that. While you were down there doing trick photography why didn't you clean it off.
Niki,
In my first response I overlooked a key words, like connector for fuel heater = trip to junk yard.
