fuel in oil???
any one ever pull there motor ?
Rear Brake Caliper Leaking
Im getting fuel in my oil. I changed my injectors and no help? It must be the cp3? took it off shaft is fine. Can or should you change the seals if so were do you get them? Thanks#@$%!
I had similar problem. Did a leak test with dye in the fuel and UV light and could not find leak. They pulled injectors and put them on test stand #5 wasn't within spec cleaned and reinstalled and I've been ok. Hope this helps. Do a search for more info.
