Hello everyone, I just joined TDR. 2003 Laramie 3500 High output 5.9 180,000 miles single wheels 6' bed all stock (LT285/75R17 Tires) Brought it new in the box LOL
I have a fuel in oil issue. It's a long story so here goes. I noticed fuel/oil in my driveway and checked under my truck, it was wet with diesel and smoke was coming out of the blow by tube under the truck. I checked my oil and it was around 5" above safe mark. After some research I came to think maybe my fuel connectors were leaking. (connects to injectors) I came to this conclusion by the following information: Truck starts right up and runs great, no smoke. I found a leak at the fuel line to my filter canister. I will change that. So what I did so far is change my oil, I got a little over 2 gallons of diesel out of my pan. Not good.... I replaced the fuel filter also. I drove the truck about 30 miles and the oil had grown about 2" on the oil stick. I ordered new connector tubes and are replacing them now. I have one in, when I took the 2nd one out it was wet with diesel, I'm not sure if that's normal or not. The dealer wanted to replace all injectors, tubes for $6000.00. I can't do that so I have been reading and reading and reading. LOL I joined TDR and just ordered a service manual. Any input from ya'll would be great!! I'm no mechanic but I'm going to try to beat this problem for less then the 6K hopefully with help from ya'll. Thank in advance
