LWells
Hoping to summarize your opinions on injectors – just had one fail (it appears) so it’s time to decide the way forward. I’ve looked back at the threads, though it is tough to uncover all the info since “injector” is mentioned in so many different circumstances. Here goes:
1) Should I be worried that I have some ongoing problem having now lost two injectors – one at 90k, one at 106k miles? My truck is bone stock since 20K, it had a moderate tune and a pressure puck at 20k when I bought it – I stripped down to pure stock immediately – no hard pulling either. Great thread history suggests this is early but not unusual?
2) How hard is it to do this myself? I’m generally handy, done plenty of “bolt on/off” work on a number of vehicles, but I am no mechanic, haven’t played with fuel injection, and I don’t have any special fuel injection performance measuring/adjusting tools. Service manual procedure sounds easy enough. But I’d hate to find out it’s really hard if you have never done it before, or don’t have a lot of fuel system tools and experience. Or worse – that you could easily do serious damage with an east to do rookie error.
3) Now the biggie – which injectors? I don’t want to try and get you active folks to agree, just want to make sure I understand your opinions. When I dropped an injector on the road, Cerberusiam, Big Papa, and a few others were really helpful with advice. Reading the threads I see Cerb, TCDiesel, and even Matt from BBI have had a good discussion. Do I have the following right:
a. Consensus among most (not all) is Bosch remanufactured injectors are not a great choice (but get ‘em from Geno’s if you go that route).
b. Brand new, stock performance, Bosch Injectors – are available, however it seems like there are many false choices out there that either still have used bodies, are new but not stock specs, or have other issues. In particular Bosch Motorsports are poor choices (universal agreement). Cerb says true new ones are easily obtainable from Injectors Direct, and TC sells these himself. Correct? (This seems to be the most critical question – supplier for truly virgin Bosch stock performance).
c. BBI injectors - Matt gives a good pitch for his product, TC and Cerb disagree a bit; with Cerb saying Bosch new are good but BBI are better (Ozymandias and JDoremire here too I believe), and TC holding Bosch new as best. Correct?
i. Question on BBI – with the 0.5 set (closest to stock?), it is still providing more fuel than stock, so the tradespace must be: Performance, fuel mileage, emissions, and engine life. BBI’s are providing increased performance at the expense of which of the others? – Assuming I’m not going to “balance” this trade by adding some special tuning.
That’s a lot of questions, sorry, but you’re help is greatly appreciated.
