Archived Fuel issues
Archived oil drain plug
Archived Coolant leak ? ?
01 Cummins 24v 4x4
My truck is missing at medium throttle during acceleation. It sometimes will die at this moment and i must bleed the injection lines and it will fire right up and run great. Tends to do it once it is warm. Have 15 psi directly after lift pump and fuel pressure drops to 2 psi at injection pump. Filter is new. I have a comp pro chip and stage 5 +150 hp injectors, currently running 44 psi boost with 14cm turbo housing and 4 in exhaust. Any suggestions welcome.
You are dropping 13 PSI at the filter? Definately something wrong there. Better check free flow after the filter.
It may or may not be the problem but need to be looked into.
