Completed my FASS install today to correct low FP issues. Works like a charm 16 psi at idle and 12 psi WOT. The only issue some fuel dripping off the bell housing. Looks like it is coming from some where above starter. Everthing that I plumbed is dry. The only thing I can figure that since I hooked up the FASS to the old fuel filter inlet and left the old high pressure side of off the old lift pump dangling. Where does the fuel from the fuel drain manifold go? Is it coming back through the lift pump and soaking the back of the engine?
