Fuel leak after fillup
heard fan today 1st time
Good evening to all from a new member
I fueled and topped off the tank I drove 20 miles and stopped the truck and smelled fuel and found leaking fuel comming from the left side of engine, running down onto the front carrier hsng, 4x4, I looked under the truck and was unable to determine where the fuel leak was comming from. I drove home another 30 miles and let the truck cool off and looked for a leak with the engine running and could not duplicate the problem. . Did the fact that I topped off the tank on a hot day 90 degrees have anythhing to do with leak I experienced? It hasn't had the problem before.
If it is a small leak, you may check your water drain line from your fuel filter. Make sure it is closed.
Also, the fuel return line from the injection pump has a problem with cracking, but that will cover the entire firewall with fuel. That is a warranty fix.
