the other day after changing out a leaking transmission line I noticed a small diesel leak. Looks to be coming out of the fitting circled, the return line? Tried to take the fitting off and couldn't get it, although I didn't try real hard. What are my options here get another solid line? Replace with rubber line? leak was coming form line circled in red.
update:leak has gotten worse and appears to be leaking form the lift pump on the filter housing. I took the lift pump off to get better access to that line and it appears to be leaking pretty good now from it, it is running down the pump and dripping off of it. Is there a o ring that is messed up on the lift pump? felt something rubber inside of the filter housing where the lift pump attaches to it, tried to pull it out and couldn't. Next plan was to take it apart again and take the filter out and look in there to see if there is an o-ring that isn't sealing up correct. If that is the case does anyone know what size o-ring it would be? or if it needs to be a special one? Picture was taken when it was just leaking out of the line, it has since gotten much worse. Thanks, Marc.
