Fuel Leak at KSB Solenoid Truck no start
P7100 pump on Gen 1?
1989 D350 Going Problem!!
My brother's '93, which has had the injection pump done a couple of years ago is leaking fuel at the fuel line which goes into the KSB (cold start advance solenoid). The truck won't start anymore. How does one fix this? The truck is rough and has over 400,000kms on it. If the pump needs to be done again. It will be a parts donor to hopefully a lower miled truck with a bad getrag that a guy could get cheap.
CR Toney
They may have rebuilt the pump but missed the KSB? I did my own KSB back in '07. Its easy and I'm not a Professional Wrench. My thread is located here; https://www.turbodieselregister.com...ram-forum-1989-1993/184307-ksb-fuel-leak.html
There is a blow-up schematic.
I dont know if you have another issue. If you get the KSB fixed and it still wont start, post again. There could be any number of issues that other folks on this Board, that have a greater level of expertise than I, will point out to you. GregH
