I have a fuel leak at my injection pump. It does not seem to leak continuosly, but some times when idling I notice a drip under the truck. Furhter investigation reveals that when you start the engine fuel seems to well up where the front of the pump attaches to the gear housing. If you watch it, you don't see the fuel except when you first start the engine. Also I observe that fuel is NOT leaking into the oil pan (not making oil).
Engine is running fine, not smoking and not getting air in the lines, best I can tell.
Any conclusions as to what might be leaking and what steps might be needed for repair ? About 133K on the clock... .
