Hi, everyone. I have had a fuel leak at the front of my injection pump for a while now, it is where the pump connects to the gear case housing area but its on the pump. It appears to only leak when cold and after a warm up cycle it seems to stop. I think that it is leaking out or under a bolt where the a fuel line crosses over. I will try to get a picture when I get home. The pump seems to run fine and the motor is great so I don't know if it can be fixed or needs to be replaced. I don't drive the truck a lot these days but would like to drive it more but I definitely can not afford a new pump or rebuild. Does anyone know a responsible and knowledgeable 1st gen mechanic in the Nampa-Boise Idaho area?
Thanks, Corey
Thanks, Corey
