I recently had a fuel leak in the return line, replaced both lines and fuel filter, now it idles about 50 to 75 rpm lower than it used to.
BTW - thanks All for the recent tips on how to access the lines (leaning the brake booster made all the difference - just a few bandaids needed -).
The truck sat for about 5 days before I could fix it - just thinking maybe a lot of fuel would have drained back into through the supply line empting the P7100. I had to prime it about 300 pushes (ouch - my thumb!) before it would start. When it started it coughed sputtered then when it got to constant rpm about 34 seconds later it idled at about 600 after running about 3 minutes it now idles at about 750 rpm awioth is about 75 lower than previous.
Any ideas to what has caused this - can I drive it or do I need to purge air (if that is possible) or something first.
Thanks,
Paul
Thanks,
Paul
