waltmoe
I change my VP44 injector pump but I cannot get the high pressure fuel lines at the cylinder head from leaking on cylinder number 1 & 3. I toque the fuel lines at the head per the manual to 28 FT/LBS or 330 IN/LBS. When truck is cold, I let the truck idle and I have no leaks until the truck has idle for 8. 0 to 10. 0 minutes or driven and warmed up. Do you have any suggestion how to eliminate this problem? Please help. Thanks
2002 Dodge 2500
2002 Dodge 2500
