I've developed a substantial fuel leak coming from a rubber line that comes from behind and to the inside of the filter housing. I'm looking down on the engine from the driverside onto the filter. There is a bracket mounted immediately to the rear of the filter and toward the engine. A metal tube comes out of that bracket and it has a hose attached to that going toward the firewall. There is also a soft rubber line to the inside of the metal line going down to a smaller metal tube then to the firewall. That is the line that appears to be leaking, but up in the bracket. For the life of me, I can't see where the line is going after it goes forward thru the bracket or exactly where the leak is. I''m going to get some mirrors, but figured there would be someone familiar with what these lines are.
