Engine/Transmission (1998.5 - 2002) fuel leak on back of vp44
Engine/Transmission (1998.5 - 2002) New Guy
turbo dean
Hello to all,i've had a wet spot on a couple of the fuel injection lines coming out the back of the vp44. the last couple of days it really started to leak, getting the hole lower end of the motor wet with diesel fuel. Called my local 5 star to see if it was coverd under warrenty, they said they would have to put a part number into the system to tell. My question is if any body has had this type of problem before and if it was coverd under warrenty? the warrenty book just says fuel injection pump and fuel injectors.
First order of business would be to check the tightness of the injector lines attached to the pump to see if any have worked loose...
