Neighbor has a fuel leak on the left side of his 07 5.9 and am wondering best place to look. The truck has lost it's prime and fuel under truck, and drips slowly when turned over. It might be a fitting on the rail, there is tell tail sign of fuel on #2 on the rail nut. I am guessing high pressure has sent fuel all over in the immediate area, and also wondering if there is a primer button, other than turning the key on to activate the fuel pump. It goers about 1 1/2 seconds, and off. No codes, the key trick says DONE and the check engine light flashes 10 times, then quites. So what do you guys suggest? where to go.
Thanks for your help and suggestions.
Maybe this should have go to the 911 but its my neighbors truck, and its cold outside.
