Fuel leak/spray?
Puff of smoke.... NOrmal??? Leak down?
Questions: changing cp3 & injectors
Hello all,
I just returned from a 950 mi. trip & noticed fuel on the driver side frame (shortbed). It seems to go from under the driver seat to about where the fuel filler neck is--this is on the frame. It is all along the frame, with a couple of spots where there seems to be almost enough fuel to form a drop. I have the Smarty 4. 4 beta set to level 1 (150 hp). Very curious if this could be related to increased fuel pressure or ? I'd really appreciate any feedback so I might figure out where the fuel is coming from, and why.
Thanks in advance,
J. S. :)
2004 qc sb 4x4 auto, Smarty 4. 4 beta, Goerend, 4" turbo back exhaust w/ 51" Donaldson, PSM air kit, cool hose, CFM + air horn
I've also noticed a little fuel along the frame side of the fuel tank. I looked at the fuel lines with the truck running, but didn't notice any leaks. Any ideas?
High psi fuel line going into injector 5 or 6 ? is prone to cracking. Make sure fuel is not running down firewall from one of these lines. se CAUTION! High PSI fuel can harm or worse.
Thanks for the reply. It doesn't seem to be coming from near the injectors. I did notice some fuel around the back of the fuel filter; there are 2 hoses there that have fuel on them. I'll look closer & see if I can't pin point. Any thoughts on this?
