Archived fuel leak when running
Archived 4x4 not engaging
Archived transmission removal ?
I'm thinking this is a fuel return line leak. Drips in a stream off the bottom of the bell housing. What size are these lines? Any suggestions for procedure?
The supply line is 3/8" and the return line is 5/16". There are many different ways to replace them.
I replaced and re-routed my return line 3 years ago with some hose, 4 clamps, and basic tools in @ 30 minutes and she's still going strong. I took the return line loose at the pump (where the overflow valve is) and broke it off at the bracket by pushing it back and forth, then cut it off sqare and cleaned it up. Then I flipped it over and slid the new hose on and put two clamps on it. Then got under the truck and reached up as far as I could and cut the rubber line. Then I disconnected the steel line at the fitting, cut the steel line close to where the original rubber hose is connected, cleaned off the burrs, slid the new hose on and double clamped that end. Then reconnect the steel lines and drive on.
I've also had the fuel filter drain valve/water sensor give up on me, so you may want to check it out.
Good luck,
Scott
Another leak I have had that dripped where yours does is the banjo fitting on top of the fuel filter bracket. The input fitting is a double stack. One line is the return line from the injectors. The other line is from the lift pump. If that is the leak you need to replace the copper washers. Four of them in two sizes.
