Details here: TDR Privileges
Go to this link. You may have a banjo fitting leaking. If so, see if it is snug. If it is, you may have to replace the sealing washers.
Check the fuel lines from the lift pump to the injector pump. Where they go into the injector pump, they screw directly on. Check to see if one of the lines is leaking. Then the high pressure lines leaving the injector pump. Don't put your hands near those high pressure line fittings with the engine running.
