Got to work this morning and noticed a real bad diesel smell. Opened the hood and had a fuel vapour coming up out of the engine compartment. Took it into the garage after work and it was wet from fuel from the front differential to the rear axle. Wiped everything down and ran it for about 20 minutes. Nothing. No leaks or anything. Was thinking that it was the fuel line from the injector pump but did that one last summer and after inspecting it, it was clean. Then a friend told me that the lift pump can leak out of the electrical connection. Did a search and have seen where several others had the same problem. What they didn't answer is can you reseal or replace the connection without replacing the entire lift pump? Or do I have to replace the pump. Any help is appreciated.
WD
WD
