KSB solenoid
It sounds like you are describing the KSB solenoid. Unplug the electrical connection and try to start your truck, if it starts its not the fuel shut off.
Depending on where the leak is you may be able to repair? If not reparable it's easy to replace, no need to bleed air out of system.
