Today i put in my old injectors dd 3s & when i started it i noticed fuel leaking from the rear of the head so i pulled the fuel lines loose & pulled out the crossover lines to look at them ,ive replaced the injectors a few times & thought the crossover lines were damaged but they looked good i put it all back together & it still leaks i also noticed the fuel pressure dropped from 22 psi down to 18 psi. Any thoughts? should i replace the crossover lines & possibly the fuel injector lines? can the injector lines mushroom if there over tightened & cause this leak?i also pulled the injectors out & looked at them they looked ok, no cracks. any help would be appreciated. thanks kurt. :{
