I am working on a guy's 94 2wd dually. It came in for a new oil pressure switch, thermostat and fuel gauge sender. He stated that when trying to fill tank completely up, he will leak fuel out under the truck. Upon pulling the fuel tank, I notice a small hose that goes from the top of the fuel module and tie strapped in a couple of spots along the filler neck hose. At the end of the hose is a plastic 90 degree vacuum fitting, which is about a foot down from the top of the filler neck. The plastic hose barb that the hose fits on top of the fuel module is on the opposite side of the plastic push lock hoses. This truck has a convertor, so I am thinking this may be a California truck and this hose could be emissions related. I am trying to figure out where this hose should be routed to prevent fuel from leaking. Any ideas would be appreciated. Thanks.
